Disables DHCP snooping on the switch.
vlan_name | Specifies the name of the DHCP-snooping VLAN. |
dynamic | Configuration options for dynamically created VLANs. |
all | Specifies all ports to stop receiving DHCP packets. |
ports | Specifies one or more ports to stop receiving DHCP packets. |
By default, DHCP snooping is disabled.
Use this command to disable DHCP snooping on the switch.
The following command disables DHCP snooping on the switch:
disable ip-security dhcp-snooping vlan snoop ports 1:1
This command was first available in ExtremeXOS 11.6.
Dynamic VLAN option added in ExtremeXOS 30.2.
